Discussion topic: After an engineer visit I can no longer get several sky channels they are now asking for a pin on th
Message posted on 28 Sep 2023 08:06 PM
I can no longer get several of the sky channels after the engineers visit today, they ask for a pin on the main box and I can't get them at all on the mini box
Message posted on 28 Sep 2023 08:12 PM
Re: After an engineer visit I can no longer get several sky channels they are now asking for a pin o
@ACam61 Having a pin does not mean the channels are not available, it simply means they are pin protected due to showing pre watershed content.
You don't say which channels are missing?
Message posted on 06 Jan 2024 01:59 PM
I have the same issue with newly delivered SkyQ mini box. Set up complete and can select all channels but if programme needs a pin input to view I just get a blank blue screen, no pin prompt. Works ok on main box.
I have retset pin and no change, also tried going to parental controls on mini box, here I get the pin prompt but justs sits there when I enter the pin, on main box goes straight to sub-menu as soon as 4th didit entered.
Any suggestions please?
Message posted on 08 Jan 2024 11:09 AM
Bump, trying to get an answer
