2
This discussion topic has been answered Discussion topic: Accessing the ports on sky q LNB EL027
This message was authored by: alexedwards
Hi All,
This is probably a stupid question, but I have a Hybrid LNB fitted which is connected to my sky q box. There are to spare ports that I'm looking to connect to an old HD box for freeview in a spare room.
On the old LNB there was a push button on the side and the cover slipped down. On the new one I can't see how to get the cover down to feed the cable into there. Any help would be greatly appreciated
This message was authored by: Godfrey Answer
Re: Accessing the ports on sky q LNB EL027
@alexedwards  The rain shield just slides upwards to provide access to the LNB outputs.
Avatar for alexedwards
Brilliant, thank you! I've been trying to slide it down over them like the old style, I couldn't see that it all just pushed up!
Thanks for getting back so quickly on this, much appreciated @Godfrey
