Discussion topic: Accessibility on Sky Q. Instructions to go to settings accessibility but it like the remote won’t wo
This message was authored by: Michaela18
Message posted on 05 Jan 2025 10:20 AM
As above in question
Find out more
Message posted on 05 Jan 2025 10:31 AM
Re: Accessibility on Sky Q. Instructions to go to settings accessibility but it like the remote won’
hi @Michaela18
his message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
