Discussion topic: Access to radio channels
Message posted on 16 Aug 2025 02:55 PM
I can only access BBC radio channels all the rest have an error message and I want to know why as we have always been able to listen to them
Message posted on 16 Aug 2025 03:06 PM
Re: Access to radio channels
What's the error message? Is the along the lines of no satellite signal?
If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
