6
This discussion topic has been answered Discussion topic: A box is connected to router but no internet connection… is there a problem with sky broadband
This message was authored by: LadyJayne
Is sky internet down
This message was authored by: Chodley Answer
Re: A box is connected to router but no internet connection… is there a problem with sky broadband
@FrustratedAF wrote:
Our broadband also went off last night and now the TV won't connect to the broadband at all even after numerous unplugging and resetting attempts! So frustrating!
The TV won't or the Q box won't?
This message was authored by: Radical
It's yes. All across the UK
Mark
Sky glass 65” Racing Green - Ethernet
LG OLED 55” + Sky Puck - WiFi
Virgin Gigabit broadband with Hub5
XBOX Series S - Ethernet
This message was authored by: plymouthbloke
I've got the same issue - happened about 23:30. Says I've got a connection but no internet. Other devices connect to the hub fine. Toggled between wired and cables connection to no avail. My phone etc will connect to the WiFi, just not the SkyQ....
Assumed it was an actual Sky platform issue affecting EPG/on demand etc rather than it being an actual physical internet issue.
Should be fixed in the morning I hope 🤞🏻
This message was authored by: FrustratedAF
This message was authored by: Invisiblename
How long are you giving it to connect? Can sometimes take up to 5mins for the Sky Q to complete the handshake to the router.  If it doesn't, try restarting your router then your Sky Q
I am just another Sky customer!
Avatar for LadyJayne
Thanks now realise it was sky not my box
