26
This discussion topic has been answered Discussion topic: 48inch OLED SAMSUNG TV - apps are not fooling the screen
This message was authored by: anita+db
hi I've just taken delivery of an OLED 48 inch screen Samsung  all the programs are absolutely fine filling the screen to the edge.
However when I use go to the apps i.e. Netflix , iPlayer etc the programs have a black bar on the top and the bottom I don't really want to change the screen size on my new TV because that will affect the rest of the programs I'm sure please advise
This message was authored by: nigea99 Answer
Re: 48inch OLED SAMSUNG TV - apps are not fooling the screen
@anita+db
As @PandJ2020 says what are you watching.
I have just tried a few different programmes/films in Netflix on my SKY Q box, Firestick & TV apps - they all work the same for me
Some do have black bars top & bottom as they were shot in a different ratio (noticable on THe new film The Six Tripple Eight) whereas the TV Series CSI (series 10 #1) that I checked fills the screen.
A lot of content is not shot in 16:9 ratio which the TV is
BTW We do recommend using the TVs own apps as these usually have Dolby Vision (not sure about Samsung) & are optimsed for the TV (also if you have a Surround System capable of Atmos this)
@anita+db  Are you refering to apps on the TV or your Sky Q box?
It should also be noted that depending on content on a given app the screen resolution may likely be correct and is shown as intended
Avatar for anita+db
Level 2 icon
Currently it's showing the black top & bottom via SkyQ box and through the TV ON
Avatar for anita+db
Level 2 icon
Plus it's on a 16:9 resolution
@anita+db  Which app or apps are affected, is this on specific programmes?
hi @anita+db
What resolution is your SKY Q box set to ?
Home - Settings - Setup - Audio Visual -Picture Resolution
Avatar for anita+db
Level 2 icon
On sky app it's on 2160
What are you watching?  As 1.85:1 or 2.35:1 (etc.) programmes will have black bars.
Avatar for anita+db
Level 2 icon
It appears it seems to be affecting Netflix & IPlayer , Prime video ,plus some adverts are being affected
ITVX is ok
Avatar for anita+db
Level 2 icon
Picture resolution on the TV setting it's 16.9 on sky setting picture resolution is 2160 8. Bit
@anita+db
Avatar for anita+db
Level 2 icon
Thanks just checked both of your suggested programs and yes match yours stated -  again tried the same 2 on TV apps and same as Sky Q - how annoying a brand new TV does this - thank you anyway
hi @anita+db
It all depends on the the content shot
Many Older TVs will  stretch , Squeeze  or Crop the picture so that you always filled the screen
Modern 4K Tvs will not do this but instead add black bars either Top & bottom (or Left & Right for older 4:3 content)
By adding the black bars you are seeing the picture in the screen ratio that the makers intended
it may seem a bit strange if you are not used to it.
I have always preferred to see content in the ratio it was shot in
Your TV may have the option to 'zoom'.  It will fill the screen by chopping bits off.
Although I think many TVs don't have this option when the source is 4K/2160p -
My Panasonic  doesn't allow Aspect to be changed with such inputs
