Discussion topic: 3 Sky Q Mini's all showing 'No satellite signal'.
Message posted on 23 May 2024 08:06 PM
Apps all work ok, so network connection is ok. Tried network reset and factory reset on the Mini's and still no joy.
Message posted on 23 May 2024 08:08 PM - last edited: 23 May 2024 08:08 PM
Re: 3 Sky Q Mini's all showing 'No satellite signal'.
hi @Maccy101
The minis all rely on the main box so the first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on each of the mini boxes (although you may be OK without this)
@Maccy101 no satellite signal has nothing to do with your internet connection
the dish itself may have a loose cable or be out of alignment with the satellite
Message posted on 23 May 2024 08:13 PM
Thanks for the reply, it's just the mini's as the main box is working fine.
Message posted on 23 May 2024 08:15 PM
Yes the main box may appear to be OK but sometimes needs a restart for the minis to work.
So,me funtions of the main box only affect the minis
Message posted on 23 May 2024 08:27 PM
Rebooted main box and all 3 minis still the same. I can't believe all 3 boxes are faulty.
Message posted on 23 May 2024 08:41 PM
Hi @Maccy101
Try the following complete sequence.
if you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
Then try rebooting the main Q box and then when this is completely back up and running reboot the minis.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 23 May 2024 09:20 PM
Hi, @oldfella
Thanks for the reply and suggestions.
Followed all of the steps and still the same problem.
Frustrating to say the least.
I suppose an engineer visit will be the next step.
Message posted on 23 May 2024 10:32 PM
UPDATE :
Fingers crossed, problem solved 🙂
Last resort I reset the hard drive on the main Q Box. This will delete all recordings.
All 3 Mini's now back online.
Thanks for replies.
