Discussion topic: 2nd sky q remote not working. Not sure if its set up to work this tv brand.
This message was authored by: Happyeyes
When I got Sky q I wanted a second mini box for the upstairs TV. As I hadn't yet got the tv up & running,  the engineer set up the box for the new tv brand,  & said he hoped it would work. (Apparently the remotes don't work on any tv, only the one it's set up for! ) This one doesn't work & I don't have any instructions as to how to fix it.
Can anyone help, please, without getting too technical?
Re: 2nd sky q remote not working. Not sure if its set up to work this tv brand.
Hi @Happyeyes
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Avatar for Happyeyes
Thank you, oldfella. I now have a working TV.
Yeah the reason they don't work on just any TV is that all the TV manufacturers use different infra-red codes. There is no standard.
