Discussion topic: 2nd q box not collected to the WiFi and not work at all
This message was authored by: Bigstu1984
We try to watch the sky q on the second box what in the living room try resetting the box and on all and still not loading up it just goes on the main page of sky help page and cannot change the channels with the remote
Re: 2nd q box not collected to the WiFi and not work at all
Hi @Bigstu1984
With the Q mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
If you still have the same issue check the home button or any other button is not stuck in on the remote.
Avatar for Bigstu1984
Thank you for the help Iv got it working
