1
This discussion topic has been answered Discussion topic: 2nd mini box has to be reactivated every day
This message was authored by: TerryGoodall
I have main sky q box then i have another sky mini box in another room and i seem to have to reactivate most days.
Re: 2nd mini box has to be reactivated every day
Hi @TerryGoodall
Reboot the mini as above.
Hi @TerryGoodall
Answered - Go to Answer
