Discussion topic: 2nd TV on Sky Q
Re: 2nd TV on Sky Q
@Blue+Ant wrote:
Hi, yes - definitely no box.
When the engineer first installed the dish he put a cable in upstairs and a second downstairs. The downstairs one is connected to the box, and the upstairs cable screws directly into the back of the TV.
I do have an old box that I used to use on an old TV if it's needed, but it's not in use at the moment
@Blue+Ant that s fine as Sky should put in a hybrid lnb to support existing freesat equipment just wanted to make sure that you weren't taking a cable from your downstairs box up to your upstairs box via the RF coax out
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
