Discussion topic: 2016 UHD Sky Q Box Becoming Painful
This message was authored by: SkyVIP-Customer
We've had this box since we took Sky Q and it has been amazing.
However, after nearly 9 years of service it is starting to become a bit painful.
Smart Apps are slow to load and sometimes very dark and unwatchable, and sometimes it pauses or we have some odd audio issues, meaning we revert to the versions installed on the smart TV instead, where apps run fine.
Also, the box is needing to be rebooted much more frequently and regularly reboots itself overnight too.
Are these issues everyone puts up with, or should we be speaking to Sky about getting a new Sky Q UHD box?
If they do replace it, with they just send out the box or does it require an engineer visit?
Is a replacement box chargeable?
Re: 2016 UHD Sky Q Box Becoming Painful
Hi @SkyVIP-Customer
A great many Q boxes of this age are in use;   Mine included.
First thing to try is  a Reset Settings in the Q box hidden menu.  This should revitalise the box.
This message was authored by: Invisiblename
@SkyVIP-Customer  The Sky Q box reboots by design each night (normally around 2am)
I am just another Sky customer!
If the reset doesn't do the trick, then log in with your Sky ID and work through the online Sky Q help here: Sky Q - Fixing a problem
Once you reach the end of the flow, you should be offered the option to order a replacement box. No charge and the box is delivered and you swap the box with the one the driver brings. Make sure you keep hold of the viewing card.
More guidance here: https://www.sky.com/help/page/sky-q-replacement
There aren't any "new" Q boxes these days, only refurbished, my current 2TB has been with us 5 weeks and is a mess, missing recordings, faking power cuts, crashing on downloads etc. none of which a reset seems to be able to solve.
I worked through the flow choosing "hot and noisy" as I also had fan problems and that was the closest matching issue. I had a dispatch text within an hour and the new box should be here tomorrow.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
