Discussion topic: 2 MINI BOXES ON SKY Q DROP OUT AND SAY "TECHNICAL FAULT" DESPITE THE NETWORK AND SKY Q BOX CONNECTIO
This message was authored by: GWMWHW
2 MINI BOXES ON SKY Q DROP OUT AND SAY "TECHNICAL FAULT" DESPITE THE NETWORK AND SKY Q BOX CONNECTION SAYING CONNECTED
Re: 2 MINI BOXES ON SKY Q DROP OUT AND SAY "TECHNICAL FAULT" DESPITE THE NETWORK AND SKY Q
Hi @GWMWHW
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
