6
This discussion topic has been answered Discussion topic: 2.15am and sky Q switched off my tv
This message was authored by: Diane2
Hi,
I’m new to Sky Q and got a message to say something like your tv will switch off in 1 minute due to auto power off. To keep watching press any buttons except the power button. Should I have pressed any button before the tv went off as I thought I had to wait until it had switched off, and now I can’t switch it on or should I reboot the Sky Q box.  And when it's working normally, should I leave the Sky Q box on at night or do I have to put it on standby or switch it off or something. I've only just had Sky Q installed so it's all new to me and I'm a senior citizen. Does this mean Sky Q is set to eco mode, and how do I get it back to working normally please. Many thanks for your time.
Re: 2.15am and sky Q switched off my tv
@Diane2
It does appear your box is in eco mode. This link explains how to change the settings if you frequently watch TV during the night. You will have to wait until the box fires up again at about 0545 to change it
https://www.sky.com/help/articles/using-the-standby-settings
@Diane2
And yes you should have pressed a button while the message was showing.
Avatar for Diane2
Many thanks for that, I'll know now if it happens again, very much appreciated
Avatar for Diane2
Hi,
thank you so much for your help it's very much appreciated. I've now got my Sky Q box switched to 'none' rather than eco mode. Should I leave the Sky Q box on at night or do I have to put it on standby or switch it off or something. Many thanks for your time, kind regards,
Diane2
@Diane2 wrote:
Hi,
Diane2
@Diane2 you should put it into standby at night when not using/watching it
Avatar for Diane2
Hi,
Thank you very much for your help it's very much appreciated,
kind regards
Diane2
Answered - Go to Answer
