Discussion topic: 1 channel not working. Channel 319 (Great Christmas)
This message was authored by: C_J_B1
The above channel stops working as soon as it becomes Great Christmas but as soon as it's back to Great Movies it starts working again. This satellite issue only affects it for Christmas. Happened last year as well.
I have an engineer booked to call out but it's a waste of his time, if it can be sorted remotely but I can't seem to get to speak to a person.
Re: 1 channel not working. Channel 319 (Great Christmas)
Hi @C_J_B1   The correct route is viewer relations by emailing viewerR@sky.uk
Avatar for C_J_B1
Thank you. Appreciate that.
@C_J_B1
What do you mean by 'stopped working'? Any error message?
Avatar for C_J_B1
The screen is black with a message on the top about problem with satellite signal. And it's only on this channel and only when it becomes Great Christmas. It will be back working after Christmas
Are you in UK or Ireland? If UK, do you have problems with the other Great channels like Great Action? If Ireland, does NHK World (507) work?
The change from Great Movies to Great Christmas is purely cosmetic, there are no technical or transmission changes, so that alone shouldn't cause a no signal message.
@C_J_B1
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️ a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News).
▪️following adverse weather wait times for an engineer will probably be significantly longer
Avatar for C_J_B1
I'm in Ireland and yes 507 has the same no satellite signal message.
@C_J_B1
You need an engineer then. It can't be fixed remotely.
Avatar for C_J_B1
I have an engineer visit booked so glad to know it's not a waste of a visit.
Thank you
