Discussion topic: 1 and 3 buttons aren’t working
This message was authored by: Jay1968
My sky q remote isn't working 7 and 9 flash but no response from 1 and 3?
Re: 1 and 3 buttons aren’t working
Hi @Jay1968
The Q box must on with green led and you must be pointing your remote directly at the Q box when you press and hold 1 & 3 together.
This message was authored by: ThePope27
@Jay1968,
Try 7+9
Then 4+6
Then 1+3
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Jay1968
Didn't unfortunately- I ordered a new remote and now working well apart from I can't work the volume on it if anyone can help? 😁
Try this,
  1. Press Home on your remote
  2. Select Settings, then Setup, followed by Remote Control
  3. Select the remote you're using
  4. Select Control your TV then Find it for me and follow the on-screen instructions
Avatar for Jay1968
You're a genius Thankyou so much! 😁😁
