What is my Sensor Bridge for?
Before installing any sensors, you'll need to make sure that your Indoor Camera and Sensor Bridge are properly connected and online. This is important, as the sensors will not be able to be installed without first completing this step.
Image of  man holding an Indoor Camera.Image of man holding an Indoor Camera.
How do I set this up?
You'll need to connect your Indoor Camera and Sensor Bridge by plugging your bridge into the back of the Indoor Camera. Make sure they both show a solid blue light. This means your setup has been successful.
Illustration of an Indoor Camera showing show the solid blue light.Illustration of an Indoor Camera showing show the solid blue light.
Good to know: If the Sensor Bridge is showing a solid blue light, it is online and ready to connect to a Sensor. If it is yellow, you may need to 'reboot' it. Reboot by disconnecting it from the Indoor Camera and plugging it back after a minute.
If the Sensor Bridge is still showing a yellow light, please ensure your Indoor Camera is also showing a solid blue light.
Take a look at our step-by-step installation videos here:
How to set up your Sky Protect Indoor Camera - Sky Help
You can also take a look at a detailed help article here
