Discussion topic: Sky protect door bell not charging
This message was authored by: Stew4
My Sky Protect doorbell is not charging. It has been on charge for 4 days and the orange charging light on the bell is still constant. When I check it on the Protect app it still shows that it hasn’t charged. I have tried charging the bell using the correct procedure stated. (Using the USB on the chime unit).
This is the second bell I have received from you regarding this charging issue. It appears to me that these bells have an inerrant fault with them
Re: Sky protect door bell not charging
Try this.
Remove the doorbell from charging, so remove the usb cable.
Next to the usb slot under the flap is a switch, turn it off.
Leave the doorbell off for at least ten minutes.
Switch the doorbell back on and charge using the usb cable to the chime.
A charge of about 6-8 hours is all that is needed if its low or a charge ovenight.
Avatar for Stew4
Hi ge
Done that several times. Then when I reconnect it to charge it flashes orange for around 1/2 hour then goes constant orange
This message was authored by: Stottie
I thought contant orange meant it was fully charged?
Avatar for Stew4
Hi. So did I but it hadn't charged. Been in touch with Customer Service. Sent them a photo and they are sending a replacement out
When the doorbell is charging it won't update the battery level in the Sky Protect app. You'd have to disconnect the charger and then allow the doorbell to reconnect to the chime to get an accurate battery level.
Avatar for Stew4
Thank you for your information and support
