This discussion topic has been answered Discussion topic: Sky protect app problems
Message posted on 18 Feb 2024 03:04 PM
After charging my video doorbell and putting it back have found that it doesn't warn me that someone is approaching door. It records but I am getting no audible alarm on my iPhone which I was getting before can someone tell me what I am doing wrong
Message posted on 19 Feb 2024 11:26 PM
Have sorted it thanks
Message posted on 19 Feb 2024 02:04 AM
Re: Sky protect app problems
@Drse when you are in the app click on the video doorbell then click on the cogwheel at the top right hand corner
under video doorbell settings click on the cime sounds and chech motion detection is turned on if it is check that the volume is turned on
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Feb 2024 11:19 AM
Sorry still not working
Message posted on 20 Feb 2024 05:47 PM
@Drse how did you sort it in case someone else has the same problem
Message posted on 20 Feb 2024 05:51 PM
I had to remove videodoor bell from app and chime and start again. Trouble was it took about four times and suddenly it worked. A bit worried when I have to take it down to charge it might happen again
