Discussion topic: Sky Protect motion sensor not connecting
This message was authored by: asgt1974
I am unable to add either the Motion Sensor or Contact Sensor to my Sky Protect.
I have set up the doorbell and camera and both are working. I have plugged the Sensor Bridge into the camera and it has a solid blue light.
When I try to add either sensor they flash red but then do not connect to the Bridge.
I get the same with all sensors.
Any ideas what I can do?
Thanks, Andrew
This message was authored by: lauren1994.
Re: Sky Protect motion sensor not connecting
I'm having the exact same issue even contacted sky have tried different phones and a new wireless usb reviver and still no luck
This message was authored by: ANDY1254
Got my pack yesterday and was having same issue,then maged to get a door sensor working,but that was it,tried all the unplugging of the sensor bridge,then the indoor camera unjooned itself and had to rejoin it,then my wifi went down and since then i the sensor bridge isnt even showing as joined,to be honest im thinking of sending back,looking at my insurance quote its actually £200p/yr dearer for having this rubbish tech.funny i thought it was free,works out £250 free tech is costing me £400 over next 2 years.
This message was authored by: keith292
i have same problem
I complained and found out its the sensor bridges  some are faulty, new one sent out and all fixed.still dont rate the equipment,especially the doorcam, takes that long to connect that people have left before it get contacted,and the leak sensors constantly have high humidity alarm issue's.
This message was authored by: Skybroadbandister
I have sky protect it absolutely Junk
SKY are selling us Junk. The Equipment is shockingly Bad Amazon rung my video door bell i am disabled person with mobility issues i was hoping to talk to the delivery guy say please leave my parcel in my wheelie bin it took 3 minutes to load Amazon left within 30 seconds. Then the door sensors wont connect sky protect is a ripp off.
Jkb
This message was authored by: Norbsey
My sensors are either 10-15 mins delayed or show open when closed and vice versa. When I first got the product it was class, now it's garbage
@Norbsey you could try removing the sensors from the app then adding them again to see if that helps
This message was authored by: Jake301
All the equipment is a bunch of junk. By the time its loaded, it's been about 10 minutes and you can watch yourself being robbed on a recorded video. According to the advert it's all worth over £250 yet I've got a new doorbell for £30 off amazon. You can get indoor cameras for about £20 and you can get 4 leak sensors from B&Q for £25. Full set up for £75 and they're all miles better than this crap.
@Jake301 I have mine since July 2023 and had no problems with my doorbell, camera, leak sensors, motion detector or the door sensors they all work pefectly and I know others that are having a similiar experience to me my detors ie doorbell etc inform me almost instantly wether there has been bewll pusede or motion detected and can look at the live pictures straight away
Also,had my kit since early summer last year.
Not had any issues with my chime/doorbell, indoor camera, the sensor bridge with two door sensors, motion sensor and three leak sensors.
They have all recorded, alerted and sent notifications on that time accuractly and all works fine with app at home and away from home in that set mode.
Recording from the doorbell is accurate and regularly records daily.
The battery on the doorbell with my regular recording lasts a month after a recharge.
This message was authored by: Richard+Westwood
Less than a year old and the moeion sensor and one of the leak sensors have failed
What have you tried.
Removing the sensor bridge for a good ten minutes and more sometime wakes up the sensors again.
Rub your hand over the bottom of the leak sensors again to wake it up again.
Try watching the motion sensor YouTube video in the Sky Protect app under the ? Help section that shows how to reset the motion sensor with using the reset tool.
The batteries in your Motion Sensor and leak sensors should last between 12-18 months.
When the time comes to change them, you’ll need to do so safely. The Sky Protect app will notify you when the battery is ‘low’ and ‘critically low’. Maybe you had not noticed it in the app.
There’s no need normally to change the batteries unless you get either of these notifications, but you could try.
You can only open the battery cover with a small flathead screwdriver on the motion sensor.
