5
This discussion topic has been answered Discussion topic: Silly question where is the Ethernet port on Sky Q box or fibre broadband for installation of the ch
This message was authored by: FelixandDotty
Where is the Ethernet port for installing the doorbell chime I have sky Q and fibre broadband looked on both but can't see either
This message was authored by: lettice Answer
Re: Silly question where is the Ethernet port on Sky Q box or fibre broadband for installation of th
On the chime connect either the supplied ethernet cable to the rear of the chime, next to the power cable and connect the other end of the ethernet cable to your broadband router.
The ethernet ports on the router are usually on the rear of your router and most routers have four ethernet ports, except the Sky Q hub only had two.
You will not be able to plug the ethernet cable into a Sky Q TV box.
You do not need to use the supplied Sky Protect cable if it is too short, any cat5e ethernet cable will be fine if you have one or you can purcahse one that may be a better choice if you need a longer length.
Avatar for FelixandDotty
So how can I connect it if I can't put in Sky Q?
@FelixandDotty if you donthave enough router ports ine the back of your router then you could purch an unmanaged switch a google search of unmanaged switches will find them for you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Thanks will do also does a sky stream have a ethernet port?
Yes, as an option for its own data connection, but a Stream puck is a simple WiFi client device and cannot be used to connect another bit of hardware back to a network.
