Discussion topic: Re: Security cameras won't connect to my network
This message was authored by: cleopatra
Just got the protect stuff and camera driving me nuts by just repeating " ready to connect "
This message was authored by: Clareridds
Hi @cleopatra
There is a Sky Protect app with a dedicated live help chat which can help diagnose the issue you're having here.
Clareridds
Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by: AmGhai
I'm having the same problem with the indoor camera. I have followed all the steps and amended my Wi-Fi to ensure it's connected with the correct networks
i believe the device is faulty; how do I get a replacement?
If you have followed all the steps in the app help guides, especially the 'Inddor camera troubleshooting guide' and its still not working, would suggest using the support button at the bottom of the help within the app and using the 'Send us a message' link to work with the Sky protect team to help.
This message was authored by: oldgreenbee
I had a problem whereby the camera wanted to connect to the 5ghz WiFi. It needs to connect to the 2.4ghz WiFi.
When attempting to connect overtype the network with your 2.4ghz ID.
This message was authored by: Suzy14
If you have 5.0 and 2.4 on will it connect
It will only connect to the 2.4.
It should work when you first set it up.
Mine only failed because I had to start the setup a second time.
