2
This discussion topic has been answered Discussion topic: No ethernet port for chime
This message was authored by: Smth17
My router does not have an ethernet port. Is there another way to connect the chime doorbell?
This message was authored by: Laing1 Answer
Re: No ethernet port for chime
@Smth17 afraid not it does need to be connected by ethernet. It's very strange not to have an ethernet port on a router can you post a picture of your router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Smth17
If you are using a WiFi-only portable cellular data 'hotspot' for the connection, you could consider replacing this with a dedicated 4G or 5G router: those do have ethernet.
