Discussion topic: Faulty door bell
Message posted on 23 Oct 2025 03:52 PM
Faulty door bell
Our door bell seems to be faulty. We charge it up all night and the batter drops 20% as soon as we turn it back on and reconnect. It needs charging several times a week and often just randomly disconnects where we have to manually reset and reconnect it to the chime. How can I get a replacement?
Message posted on 23 Oct 2025 08:12 PM
Re: Faulty door bell
If you have not tried, turn the doorbell off using the switch at the back and keep off for ten mins or more.
Then switch back on and recharge for a good 6-8 hours or overnight and see if that helps.
The Sky Protect app under Support and the ? and the help article below has some troubleshooting that may help, plus some hints for reducing the battery usage.
If you want to contact support the various contacts details are at the bottom of the article;
