3
This discussion topic has been answered Discussion topic: Charging battery for first time takes hours... between 6 to 8 hours according to FAQ!!
This message was authored by: Vincenz
Hello Sky Protect Community,
I'm very familiar with Ring doorbell that can be hardwired but not Sky doorbell! Can't believe it takes 6-8 hours to charge! Then how often it needs to recharge?
This message was authored by: lettice Answer
Re: Charging battery for first time takes hours... between 6 to 8 hours according to FAQ!!
Yes, that faq advice is correct.
I have found my video doorbell that I have used without issue since last Summer, with regular daily recording use lasts 30 days with a 6 hour  charge or even just charging overnight for ease.
In the app, click on video doorbell and under the settings icon there are clip management options that do help a lot to get the best battery optimisation and a longer charge period.
Would suggest setting to the suggested options.
@Vincenz like @lettice I've had the kit since around July last year and had relatively few problems as well, my doorbell gets low to medium (more low than medium)use and I get around 45 to 60 days on one charge although others have complained they only get a few days on a full charge
Avatar for Vincenz
Level 3 icon
Thanks Lattice, well that's not too bad for 45-60 days before recharging as long as it's on low demand.  I'll see what it likes after my first charging on Sky doorbell.
Thanks V
