Discussion topic: when out away from house, sky mobile does not have internet coverage, other phone provider has,
This message was authored by: JJ+Walsh
Sky Mobile, should automatically switch to internet and work, so with no internet no Whats App, or Home security
Re: when out away from house, sky mobile does not have internet coverage, other phone provider has,
@JJ+Walsh
You do have mobile data turned n when you are not at home ?
Avatar for JJ+Walsh
Level 0 icon
yes I do have mobile data switched on at all times
Avatar for JJ+Walsh
Level 0 icon
YES MOBILE DATA IS SWITCHED ON AT ALL TIMES
Have you checked the correct APN settings are stored in your phone @JJ+Walsh   Capital letters indicates shouting so best to use lower case when asking for help.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
This message was authored by: buddys
I don't know where you stay but I found when I was at Haggerstone castle near Berwick I got no sky service even for phone calls but when I left that area it worked fine.
