3
This discussion topic has been answered Discussion topic: iPhone air suddenly lost connection and not connecting back to sky network
This message was authored by: Krys2
Hi. My iPhone air suddenly lost connection and not connecting back to sky network. The phone acts like it had no SIM card, it is looking for a network but not connecting. I have tried all the usual restart, update and network settings but no luck. Something tells me the eSIM may need reinstalling but I don't know how to go about it and want to keep the same number. Maybe faulty phone but it seems ok. Thanks, Krys.
This message was authored by: 63johnw Answer
Re: iPhone air suddenly lost connection and not connecting back to sky network
Hi @Krys2  you should be able to delete and set up as you did when you first installed. Make sure you are connected to WiFi and have access to your emails.
https://www.sky.com/help/articles/esim-sky-mobile-activate-and-install
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Krys2
Thank you. I will try this after work. Will let you know if it works.
Avatar for Krys2
After trying with sky customer service it turns out the IMEI is black listed for some reasons. Service should be back on within 48 hours.
Answered - Go to Answer
