27 Sep 2023 07:00 PM
I have a new iPhone 15, I set up the Sky SIM initially with a new phone number until my previous number was transferred. I provided details of my old phone number and PAC code to transfer to this new phone. With a few stumbles, I made the switch and my new phone seems to work ok for making and receiving calls, and the same with iMessage. The problem is that when I check my device details in Settings>My Name-Apple ID and scroll down to Active Devices and look at my phones "Device Info" all details are correct except that the phone number displayed is the original Sky Number that came with the SIM.
There isn't an option on that settings page to change it. All other settings where the phone number is displayed show the correct phone number.
I don't know what effect this will have but I would prefer to set it up correctly. All my web searches relate it back to the Apple ID but this all shows correctly.
Any suggestions will be greatly appreciated
Bernard
27 Sep 2023 07:55 PM
Posted by a Superuser, not a Sky employee. Find out moreA replacement sim might fix these issues for you as it will come with your correct transferred number:
https://www.sky.com/help/articles/replacement-sim
27 Sep 2023 07:25 PM
Posted by a Superuser, not a Sky employee. Find out moreWhen did you give Sky the pac code you got from your previous network but the number transfer should then take place on the next working day of whick Sky will email/text you when it has tekn place so has this happened yet ?
27 Sep 2023 07:36 PM
Thanks for the reply @caesarome
I gave them the details as soon as I placed the order for the phone, they said that they would switch in 2 days but it went to day 3. After the confirmation message from Sky confirming that the old number was now in use I needed to make a few changes in settings to change the Sky number to my old number, I think mainly in iMessage..
Bernard
27 Sep 2023 07:43 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you gone to Settings - Phone - My Number and changed it if it is wrong, then rebooted the phone ?
27 Sep 2023 07:47 PM
Yes and the correct phone number is displayed, I have restarted several times
Bernard
27 Sep 2023 08:03 PM
27 Sep 2023 08:07 PM
Posted by a Superuser, not a Sky employee. Find out moreYou don't need to contact Sky as you can order it online via the link I posted.
27 Sep 2023 08:09 PM
Oh, ok, I'll try that
Thanks again
Bernard
