Discussion topic: Wifi privacy warning on iphone how do i sort
This message was authored by Kim167 This message was authored by: Kim167
Need help to sort - getting a wifi privacy warning on mobile
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Wifi privacy warning on iphone how do i sort
You have to ask your WiFi provider as to whether they support the protocol that Apple have deemed 'secure'. (WPA3)
in reality your current configuration is probably sufficient.
https://support.apple.com/en-us/102766
I am just another Sky customer and my views are my own
@Kim167
If you are using Sky Broadband, only the Max Hub (released last year) has WiFi 6 with WPA3.  The same is typical for most other ISPs:  their most recent router may have that specification, but earlier models will not.
This message was authored by twilight+princess This message was authored by: twilight+princess
Have you turned on the Private Wi-Fi Address setting under the Wi-Fi provider (Sky)?
Virginia.
Diamond Sky VIP member.
