9
This discussion topic has been answered Discussion topic: Why wont my phone work outside
This message was authored by: Kyllie
My phone wont work outside, mobile data is on, it keeps saying im currently offline, its a new handset it is unlocked. For days it said no service, that problem isnfixed its still not working
This message was authored by: 63johnw Answer
Re: Why wont my phone work outside
Hi @Kyllie  check your APN settings.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
This message was authored by: JDeeIE
I assume you mean data?. Or all services ?
it's working connected to broadband WiFi Calling ?
but outside no ?
Have you got VoLTE on ?
Avatar for Kyllie
Surley they should all be set,
Avatar for Kyllie
Yes thats on, mobile data is on, the phone works inside on wifi, as soon as i go out side it doesnt work
Not necessarily @Kyllie have you checked ?
Avatar for Kyllie
No i havnt, i wouldnt know how or what they should be
What phone do you have @Kyllie  ?
this is what they should be.
Internet APN Settings:
Name: Sky Mobile Internet
APN: mobile.sky
mms settings
Name: Sky Mobile MMS
APN: mms.mobile.sky
Also check for issues in your area @Kyllie
https://www.sky.com/help/articles/service-status-sky-mobile
Avatar for Kyllie
  • Thank you for them, i will have a look 😊
