Discussion topic: Why am I using so much data on my new I phone 16 than I did with my older phone which was on 02
This message was authored by: rickstar1
Why am I using all my data up in days , currently at 5GB on my new I phone 16 .
My old Apple phone rarely used over 2GB per month doing everything I required ie browsing, social media, nothing has changed the way I use the phone
Re: Why am I using so much data on my new I phone 16 than I did with my older phone which was on 02
Hi @rickstar1  your phone data monitor should tell you what's using the data. The first thing to check is auto video play isn't enabled on Facebook or X (twitter).
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@rickstar1
Are videos and other media now playing in higher resolution, perhaps because a better screen and/or faster cellular connection has been detected?
@rickstar1
Or has iOS updated over the cellular link?
Avatar for rickstar1
I Cloud and I drive we're running in the background which  I were not aware of and using up my data whilst away from  WiFi .
Turned the 2 off and things looking like back to normal.
Obviously Sky manipulated this to force me to buy more data worked .
This message was authored by: daveNOS
@rickstar1 How on earth did you come to that conclussion? You had 2 Apple cloud services running on your device using the data and that is somehow Sky's doing?
More likely Apple defaults rather than a conspiracy.
Definitely an Apple issue not a sky one @rickstar1
I don't think a cellular carrier has access to those iOS settings: it's presumably Apple which has decided to default them to on because, as usual, it has decided it knows what users really need better than the users themselves.
If your previous iPhone model or cellular service wasn't 5G then this wouldn't have been available as an option: iOS detects the 5G capability.
