14 Oct 2024 10:56 AM
If mobile is not at home there is no problem but when if is in the house and wifi turned on there is a problem with incoming calls. there is an ecko on their phones that only stops when wifi is turned off on the samsung S20 FFE 5G phone. omly started when sim card chamges from O2 to SKY and as SKY uses O2 network bit strange, Told it is Gigaclear broad or samsung issue but they worked fine qith O2.
14 Oct 2024 11:25 AM
Posted by a Superuser, not a Sky employee. Find out moreTry turning wifi calling off (instead of wifi completely)
14 Oct 2024 04:10 PM
Brilliant. Thank you PandJ2020. Turned wifi calling off in phone settings. Worked a treat. Not sure how it got turned on. Noone has been able to work it out over 11 months with numerous calls to gigaclear samsung and sky technical help. From what I have now read this setting only needed if phone out of signal and google recomend it turned off on android phones.
