Discussion topic: Using phone as hotspot whilst roaming in France
This message was authored by: DaveDB
I'm going to set my phone to "roaming" whilst I'm in france, using the £2 a day set up allowing me to use my saved up piggy bank. Will my partner be able  to turn roaming off,  connect to my phone and make whatsapp, & FB messenger calls using my data? and can I connect my ipad to it as a hotspot? (I know my parther won't be able to make wifi calls connected to mine whilst abroad, as that functionality is blocked).
Re: Using phone as hotspot whilst roaming in France
Your partner should be able to do this but if they leave roaming/data turned on via their device then the £2 charge will kick in for them. You should also be able to connect your IPad but remember data wise you are restricted to your whatever your usual data package is.
