Discussion topic: Unable to order replacement phone for stolen handset
Message posted on 25 Mar 2025 07:50 PM
My daughters phone was stolen the weekend. We called sky to block it and try and order a replacement. We signed the credit agreement but got a mail to say order cancelled. Spoke to sky to be told I need to speak to credit checkers. Did that and they said no issue their end, speak to sky. Did this twice and both orders cancelled. Sky then said I need to pay off the stolen handset then I can order the new one. When I called to pay, I was told that's wrong !. Sky don't want to know. My credit score/check is spot on but sky don't want to know and won't help. I need help from someone who's been in the same position. Sick of calling different numbers and speaking to different people.
Message posted on 25 Mar 2025 07:57 PM
Re: Unable to order replacement phone for stolen handset
The stolen phone does have to be paid off but that on it's own would not prevent you from ordering another one so for whatever reason you are failing the credit check and Sky would not be able to tell you why this is as they can not view your credit records so if you don't already have access you could sign up to a site that allows you to view your records, one credit checking site they use is Experian so you could sign up to a free trial with them, just remember to cancel.
Message posted on 25 Mar 2025 08:03 PM
And if you keep trying to order the device this could further impact your credit score.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to call Sky to chase it up.
Message posted on 25 Mar 2025 08:14 PM
@caesarome I have contacted equifax and got the report from them and they have said there is no reason why it has been rejected as there is no issue with my credit score/report. I feel like I'm going round in circles.
Message posted on 25 Mar 2025 08:16 PM
@Daniel0210 Ijust feel like I'm going round and round. The credit check company says no issue, sky says there is. I'm getting nowhere.
Message posted on 25 Mar 2025 08:18 PM
At the end of the day if Sky have decided not to allow you credit on a new device there's not a lot you can do about it.
Message posted on 25 Mar 2025 08:24 PM - last edited: 25 Mar 2025 08:25 PM
Credit check companies do not set vendor's acceptance parameters. But, as noted, you can't make them give you credit.
Credit 'scores' alone are not necessarily a guarantee.
