Discussion topic: Unable to connect to the WiFi with a new iPhone 16 max using original sky sim card
Message posted on 24 Nov 2025 07:24 PM
Hi, I have just received my new iPhone 16 max from sky, put my old SIM card in , then set the phone up, but it will not connect to the home wifi. Any help would be greatly appreciated.
Message posted on 24 Nov 2025 07:28 PM
Re: Unable to connect to the WiFi with a new iPhone 16 max using original sky sim card
If you go to Settings > Wifi - does it see your wifi network and if so what happens when it attempts to connect to it ?
Message posted on 24 Nov 2025 07:35 PM
It shows up as being connected to my sky wifi , as it normally would but when I try and google anything it says it is not connected . I've tried a few things as suggested elsewhere like deleting vpn, disconnecting and reinstalling the WiFi settings but with no luck.
Message posted on 24 Nov 2025 07:36 PM
Try rebooting your router @Hannah204
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 24 Nov 2025 07:38 PM
Are you using private relay on it, if so try turning this off.
