Discussion topic: Text Messages to UK whilst roaming abroad
Message posted on 04 Aug 2024 04:54 PM
Message posted on 04 Aug 2024 05:01 PM
Re: Text Messages to UK whilst roaming abroad
Although you do not have to, have you got a spend cap set ?
Message posted on 04 Aug 2024 05:04 PM
Yes I have a spend cap set, so that is not the issue.
Any other ideas?
Message posted on 04 Aug 2024 05:05 PM
Is it high enough to cover your stay ?
What is happening when you try to text ?
Can you make calls to UK numbers ?
Message posted on 04 Aug 2024 05:44 PM
Yes it is plenty high enough, I set it at £20.
When I try to text, the system tries to send for a while and then comes ip with a "failed to send" message.
I have not tried calling anyone in the UK as no need to do so
