Discussion topic: Text Messages to UK whilst roaming abroad
This message was authored by: PaulYax
I cannot send text messages to UK from Slovenia
Re: Text Messages to UK whilst roaming abroad
Although you do not have to, have you got a spend cap set ?
Avatar for PaulYax
Yes I have a spend cap set, so that is not the issue.
Any other ideas?
Is it high enough to cover your stay ?
What is happening when you try to text ?
Can you make calls to UK numbers ?
Avatar for PaulYax
Yes it is plenty high enough, I set it at £20.
When I try to text, the system tries to send for a while and then comes ip with a "failed to send" message.
I have not tried calling anyone in the UK as no need to do so
