05 Aug 2022 11:50 AM
Moved my hubbys' mobile over to Sky a few months ago. He brought his mobile number across from old supplier but a few times, when I've texted him on the number he brought across, when he replies it comes from the number he originally had with Sky. How do we fix this?
05 Aug 2022 12:57 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Nicola-13 if this is an iPhone go to settings, phone, my number and check the correct number is stored there, if not then update it then exit and reboot your phone.
07 Aug 2022 05:16 PM
@63johnw it is an iphone and you are correct, the wrong phone number is displayed. We've tried to change it to the correct number but it won't save.
07 Aug 2022 05:18 PM
Posted by a Superuser, not a Sky employee. Find out moreIt has taken some customers quite a few attempts to get the number to save @Nicola-13
Posted by a Superuser, not a Sky employee. Find out moreIt might be worth ordering a replacement sim as that should come with this number on it, if you have more than one sim on your account then make sure you order it against the correct one:
https://www.sky.com/help/articles/replacement-sim
07 Aug 2022 05:21 PM
@63johnw sorted! Thanks so much for your help. Took about 5 attempts to save it
07 Aug 2022 05:22 PM
thanks @caesarome, this would have been the next step but managed to get it sorted.
