Discussion topic: Sky bill over usual payments
This message was authored by: Chelseamcf
Hello, my sky bill says it is 118 pounds this month when it's usually 60 and it doesn't say why it's so expensive
Re: Sky bill over usual payments
If you look at last months Sky bill and compare it with this months what is the difference as you should be able to see why there is an increase and what has actually increased.
This message was authored by: twilight+princess
Have you reached the end of your contract? If yes then the cost will rise although almost double seems excessive.
have you used data outside of your allowance or sent any MMS? This will be charged seperately. Does the bill show why the cost has increased? What about future bills?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
