Sky Mobile expands £2 a day roaming to 120 destinations
Sky Mobile has expanded its roaming offer, allowing customers to use their phone in 120 destinations worldwide for just £2 a day.
The update makes it easier and more affordable to stay connected abroad, with clear daily pricing and no need to change your plan.
What does £2 a day roaming include?
When travelling in an included destination, Sky Mobile customers can use their UK allowances for:
  • Calls
  • Texts
  • Mobile data
The £2 daily charge only applies on days you use your phone abroad. If you don’t make a call, send a text or use data, you won’t be charged.
What’s changed?
The key change is the increase to 120 destinations, giving customers wider global coverage than before.
This means more popular holiday spots and long‑haul destinations are now included under the same simple £2 a day roaming price.
Which countries are included?
The full list of the 120 roaming destinations is available on the Sky Mobile website. It’s worth checking before you travel to see exactly where £2 a day roaming applies.
