Discussion topic: Roaming in Spain; Going to Bilbao in June, how do I set up my phone for roaming in Bilbao
This message was authored by: HW57
I have very poor tech skills, I need help to set up my Sky mobile so I can use my phone for flights ect.
Thank you in advance for any support
Re: Roaming in Spain; Going to Bilbao in June, how do I set up my phone for roaming in Bilbao
Hi @HW57  all you need to do is make sure roaming and mobile data is turned on in your phone settings. Once you use your phone in Spain to either make a call, send a text or use some data then the £2 daily charge kicks in. Each 24 hour use will cost £2 so make sure the monthly spend cap in your Sky account settings is set high enough to cover the amount of days you are away.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
