Discussion topic: Roaming fees in istanbul
Message posted on 01 Aug 2025 08:32 PM
Hi I need to use my phone abroad and what are the charges
Message posted on 01 Aug 2025 08:54 PM
Re: Roaming fees in istanbul
@Sammi50 wrote:Hi I need to use my phone abroad and what are the charges
@Sammi50 Roaming in Turkey is covered by roaming passport plus and should be £2 per 24 hours, that covers data use(25GB limit) and calls or texts to UK numbers.
Calls to local numbers are charged at £3.50 per minute with texts being £0.95p per text.
You may need to adjust your spend cap if it's not high enough.
Message posted on 01 Aug 2025 09:47 PM
That roaming limit is 25GB per billing period and any useage over that is charged at £2.50 per GB.
