Discussion topic: Roaming charges
This message was authored by gsi-dean This message was authored by: gsi-dean
Roaming charges
Hi I'm away in Spain an have roaming on wen I return home will I get a massive bill ??? Thanks 🙈
Re: Roaming charges
You will be charged £2 for every 24 hours you use your phone, that charge allows you to use your usual package as if you were back home in the UK.
This message was authored by 63johnw This message was authored by: 63johnw
Re: Roaming charges
Hi @gsi-dean  the only way you would get a massive bill would be if you have used all of your normal data allowance and added extra data or were making lots of calls to local numbers as they are charged extra. If you used your phone every day for a week your extra charges would be £14 if just using the roaming passport.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
