Discussion topic: Roaming charges in Sharm El Sheik
This message was authored by: Iris+Louise
What do you pay and is there any special package you can buy for a month?
Re: Roaming charges in Sharm El Sheik
@Iris+Louise
The charges are really high so you could wrack up quite a large bill:
£2.16 per mb of Data (not Gb)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
There are no special packages you can buy so if you are going to be out there for a while you might want to pick up a local sim and use instead.
This message was authored by: daveNOS
Edited,
Duplicated information already posted.
