Discussion topic: Roaming charges but no calls made or recieved
This message was authored by HMJ This message was authored by: HMJ
I've just returned from a holiday in the Maldives. I did not make or accept any calls knowing the high prices but two missed calls are showing as charged £2.88 each even though I didn't answer. I don't understand how this works as I can't control who calls me!
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Roaming charges but no calls made or recieved
True, but you can control if you are connected to the cellular network.
To avoid charges I would turn roaming, data and cellular off.
I am just another Sky customer and my views are my own
HMJ
Hi. Sorry should have made clear I did turn it off! Thats my point.
This message was authored by 63johnw This message was authored by: 63johnw
Hi @HMJ  did you receive/listen to voicemail ?
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
Your device must have connected to the cellular network - otherwise they wouldn't know you were there... (And couldn't charge you)
HMJ
I definitely didn't listen to voicemail and there's no messages on there....
HMJ
It's strange. I definitely turned off all but got messages outlining the cost on initial arrival and a week later. I used wifi calling to call family as I knew costs were high. It's not a major issue as only two missed calls are charged for but seems odd so I thought I'd ask.
You need to check your phone settings as it clearly connected to the cellular network...  (As I said, they can't charge you unless it connects)
@HMJ
When did you turn it off, before you left the UK after you arrived ?
HMJ
Before we boarded in UK
HMJ
No - neither.
I got stung in Dom rep many years ago so always switch it off before departing!
Hi @HMJ  wifi calling doesn't work from overseas, it converts to a normal call, that will be what the charges are for.
