This discussion topic has been answered Discussion topic: RCS still showing temp number after transfer
Message posted on 22 Jun 2024 12:03 PM
Hello,
I transferred my phone number to a new sky SIM (completed 2 days ago).
Everything is now working fine except the RCS chat is still showing the temporary number. So far I've tried turning that feature off and on again, updating the APN settings, checking my phone number is the correct one in my Google account, and restarting the phone (pixel 4a) after each attempt.
Is there anything else I can try?
Thanks for any help!
Message posted on 22 Jun 2024 01:22 PM
I would suggest that it your issue then so it might be worth ordering yourself a replacement sim as it will come with this transfered number so could well fix this issue for you, not sure if this link will work for you:
https://www.sky.com/productsettings/mobile/sim/x/replacement-sim
Message posted on 22 Jun 2024 01:09 PM
							Re: RCS still showing temp number after transfer
Have you checked that your phone itself (not via your Google account) is showing the correct number ?
Message posted on 22 Jun 2024 01:19 PM
Hiya,
Thanks for your reply!
I've just looked and under phone number and it says 'unknown' but unfortunately I'm not able to tap it to add my phone number?
Thanks again!
Message posted on 22 Jun 2024 01:25 PM
Hiya,
Yes the link does work thanks - I think I'll have to do that then and keep my fingers crossed that fixes it!
Thanks again! 👍🏼
