Discussion topic: Preparing old phone for swap
Message posted on 12 Apr 2025 10:51 AM
Should I just restore to factory setting to prepare my old phone to swap. Do I need to do anything else ?
Message posted on 12 Apr 2025 10:56 AM
Re: Preparing old phone for swap
Hi @downwithsky that should be enough. Find my iPhone should be deactivated if it's an iPhone.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 12 Apr 2025 01:37 PM
thank you I have erased tings and now when I switch it on itgoes straight to the hello page. will that do?
Message posted on 12 Apr 2025 01:40 PM
If you have done a factory reset then it would start up at the hello screen so what you have done is fine as it is back to the state that it was when you first got it.
Message posted on 12 Apr 2025 02:04 PM
@downwithsky wrote:thank you I have erased tings and now when I switch it on itgoes straight to the hello page. will that do?
Yes @downwithsky that should do.
