Discussion topic: Please help! Backing up a liquid damaged phone to iCloud
Message posted on ‎30 Jul 2024 09:05 PM
Hi
i have 2 phones with sky (1 is for work) and my personal phone has been water damaged and won't switch on - is there any way of backing it up to the iCloud? 😟 Thanks.
Message posted on ‎30 Jul 2024 09:33 PM
Re: Please help! Backing up a liquid damaged phone to iCloud
If it will not switch on then you can back it up so up until it was damaged had it been previously backed up ?
Message posted on ‎30 Jul 2024 11:00 PM
I don't know. Does it automatically back up on a regular basis?
Message posted on ‎31 Jul 2024 05:40 AM
It can do if the setting is turned on:
https://support.apple.com/en-my/guide/iphone/iph3ecf67d29/17.0/ios/17.0
So have you checked to see what has been backed up:
Message posted on ‎31 Jul 2024 11:57 AM
Thank you. 🤩 I have just looked on this phone (the one I use for work) and they are on here - but they're not all there - but that's what I will have to live with. Thank you so much for your help.
So, is there a way I can set my new phone that do regular backups to the cloud?
Message posted on ‎31 Jul 2024 01:04 PM
If your new phone is an iPhone then look at the link I posted earlier as it explains how to set this up.
