Discussion topic: Not able to make or recieve telephone calls on my mobile
This message was authored by: Custard01
please urgently help i cannot make or recieve calls had have important call to recieve at 3.30pm.
Re: Not able to make or recieve telephone calls on my mobile
@Custard01
Any relevant information showing on this link?
https://www.sky.com/help/articles/service-status-sky-mobile
This message was authored by: AJ271
I am also having this issue. When checking the signal in my area. It says it is working and is fine.
This message was authored by: dpeo
Same issue. The automated message people receive when trying to call me says my number is incorrect. This is causing even more issues than just a service outage.
@dpeo
If you are able to make outgoing calls contact Sky by dialling 150 and report this issue to them.
This message was authored by: W3ndy2159
I had the same issues
i turned off/closed down my mobile then restarted. #rebooted
that resolved the issues and working fine.
