Discussion topic: No signal with sky
This message was authored by: AbdelIssa
No signal with sky
I transferred from vodafone to sky, esim , with the same number , done all the steps was given a temporary number which had no signal for 2 days but was using my old vodafone sim, now I was told it is transferred so vodafone sim has stopped and no signal on the sky sim, can't call them even.
This message was authored by: Lisa-P1987
Re: No signal with sky
Lisa - Sky Tech Team Expert
This message was authored by: twilight+princess
Try turning off any messaging apps (iMessage, FaceTime etc) then reset the network settings. I have an iPhone so can only supply instructions for that.
Settings>General>Transfer or Reset Phone>Reset>Reset Network settings.
If the phone has WiFi then you can sign in to your account & send the phone settings to the device.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
This message was authored by: Tom-W19
Hi @AbdelIssa
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
Avatar for AbdelIssa
All sorted, thank you. After it was transferred from vodafone to Sky , I done the esim activation steps again and it worked.
Thanks all.
